Actually, the same motor when wired for 230 VAC will use slightly less power because it will run more efficiently. It will run at less amps and amps * resistance == heat generated and every bit of heat generated is lost efficiency...not to mention shorter life of the motor.
As a general rule, high voltage is more energy efficient than high amperage...sometimes a lot. That's why transmission lines run at such high voltage.
You are absolutely correct CDH. Under small loads, there is very little difference in the efficiency of 240v vs 120v. It's when the load increases that higher voltages really shine by minimizing losses.
Erin F. Burke, PE
Big Washington Power Company
