Edifier W200BT earphones uses Qualcomm's new Bluetooth 5.0 chip, play more smooth. 7 hours of battery life, magnetic absorption design, 16.2 grams weight, it is convenient and fashionable to be brought when running. This is a headset that can customize the EQ mode, pair name, and support timed shutdown. Among them, the EQ mode was recreated by the senior acoustic engineer of Edifier according to the sound characteristics of the W200BT, and finally formed into four styles of classic, pop, rock and classical. Listen carefully, all with surprises.
Product Features:
● Connect with App to offer extensive functions, such as different EQ modes, Bluetooth paring, timing shutdown, etc.
● Classic, pop, rock, classical modes for premium sound entertainment.
● Bluetooth V5.0 with a range of 10 meters, ultra-low latency, high-speed transmission.
● CVC8.0 noise canceling technology blocks a wide range of ambient noise for a clearer call.
● Can be paired with two Bluetooth devices simultaneously.
● Soft and high-elastic TPE wire, skin-friendly and effectively reduce the auscultation effect during exercise.
● Separate design of earwings and earmuffs, with 3 standard specifications respectively, can be flexibly matched.
● 10mm dynamic driver units produce crystal clear sound.
● Durable material, nano-coating technique, IPX4 waterproof, suitable for multiple using scenarios.
● Magnetic absorption design, can be closed and hung on the chest when not in use, easy to carry.
● The extra wire can be buckled behind neck to prevent the hassle of swinging wires.
● Three button control for pick up/hang up phone calls, adjust volume, switch tracks, etc.
● High-density battery can last for about 7 hours.
Although the price is as low as $12.99 when use the coupon code "w200bt", the W200BT has achieved a higher level of sound quality than some products of the same price: https://gearvita.com/edifier-w200bt-bluetooth-earphones.html
Related products:
i60 tws
qcy qy19
Product Features:
Related products:
i60 tws
qcy qy19
