I like hair whittling while tree topping, splitting hairs still on my arm : D
This is what I'm trying to achieve, maybe I need an edge pro but I can get hair whittling if I take my time
I would say you have a very toothy edge, stropping a 120grit edge would I believe still leave it very toothy. That is probably what is grabbing the hairs. Good job!
Hair diameter varies tremendously between individuals as well as between different parts of the same person's body. To compare number of slices would require a standard reference hair. I knew a guy in grade school whose head hair was so coarse that it looked and felt dry the moment he emerged from the pool. I have also known people with hair like fine silk.Exactly. I have done this before, and it is more akin to "ripping" the hair than actually whittling it.
Try this, cut up the same length of hair three or four times. I have gotten up to 6 slices up the length of the hair before it gets too thin. Never gotten past 6.
An old trick when sharpening .
Try dragging the edge on a piece of hard wood a couple of times to get rid of the burr completely.
Sometimes a small straightened burr is left after stropping , and that thin burr will be hair whittling sharp ,
but will not last very long if you cut with it , in other words , the knife can actually be dull yet whittle hair because
of a tiny burr.
1234,,![]()
Mised before that it was a belt finish, the high rate of grinding makes a big difference in the condition of the edge and the reduction in particle size through fracture. Belt finishes are usually a lot finer than hand finishes at the same grit. When you say you stropped it, was it leather, canvas, felt, MDF, or on the belt sander? Did you use a compound?
yea i know i made sure to take off that straight wire burr and cut hard wood untill it wouldnt wittle,then strop again and back to wittling so i know its no wire
The edge won't be as refined as something taken through more grits, but you would be surprised at what a loaded power strop can do. Here's images of an edge power sharpened a little finer - 220 grit, and then power stropped with chromium oxide loaded leather. Note the 600 & 3000 magnification.stroped on leather with compound. . .and yes with the belt but even still that is a pretty rough grit becouse the finish on my knives are with 120 till after heat treat and it leaves pretty rough surface so i can imagine what it does to the edge so yes wile there might be a slight diffrence i doubt its that much judging by the surface finish i get o the knives wih the same grit... mayb its the way i did it really flipping that burr so man times until i got it as small as possible then to the strop and then getting rid of wire burr and back to strop. .lol long process but i like sharpening
