- Aug 12, 2013
Thanks for your reply!
Besides the part near the kick does that side look like I am getting the right idea? I will for sure go back over and work that spot. My form could obviously use work.
If I was to raise the spine a little on the side that has the Sharpie showing would I have to (or should I) do the same on the other side?
Random question while I am at it: How long does a piece of sandpaper last for a job like this? They go from black to gray quickly and seem to not be as coarse as they were before.
Stop and clean it off with an eraser, often. If you don't it will clog up with removed steel and abrasive fragments and the paper will croak very quickly.
Take your time with the sandpaper and it will come around. Keep the angle nice and acute and consider switching to a backing with less give, create the convex with a bit of wrist motion instead of trusting the mousepad to make an edge with a good arc. You'll have more control over the process. You might also consider switching to a cheap surrogate knife to learn on, you could even use a plastic knife etc, just to get the hang of forming the convex. Return to your SAK with more confidence.
Martin
Better advice than I had. Didn't know you could clean sandpaper. Should I use a large pencil eraser?
Thanks Martin! That is good to know! I thought I was going to blow through paper.
Do my photos show that I am getting the idea? Should I go and get 220 or stick with my 400 to reprofile?
So don't angle the knife to take the Sharpie off the edge, but rather continue to work the knife's shoulder at a shallow angle until I reach the apex?
Though it's not necessary?
Though I am sure my technique is poor, I still feel as though this is taking much longer than what I have read from other people's experiences.
Another thing is I swear that my sandpaper is getting dull in no time at all. I tried the eraser trick, but I think I need a different eraser.
I will give a harder surface a try and get back to you. I was under the impression that the slack in the mousepad is what made the convex.
I thought about using my Sharpmaker on the 30 degree setting to thin the edge before I convexed, but I didn't.
Sounds like a burr to me. Does it feel sharper one side of the blade than the other?
At this point it will cut paper decently, but will not shave (seems to pull hair more than cut it).
Thoughts?
