- Mar 23, 2001
O.T. Response:
Lothar,I've seen several people make pliers like those.It works,but not well from what I've seen.It's better to just turn the wire on a metal dowel rod then cut the links off.You'll still need to close the ring completely using regular pliers (or needlenose for jewelry & other small links),since the rings will "spring back".I've run across many who try to "cheat" as it were,but most of what they turn out isn't good.There's still nibs on the ends of the rings (unless they were pre-cut with a real machine instead of hand cut),or the rings aren't properly closed which allows ring slippage.
Nate,nah!! I'll stick to my old faithful piers of pliers
I still need to find 2 more exactly like mine.The ones that I use are standard pliers,but the lip is smaller than others that I find now.These allow me to work with ring diameters down to 1/4 inch.I can still get into tight spots with them,whereas I can't with other pliers that have a slightly wider lip.The ones I use have teeth as well,which is good for gripping the ring.For jewelry work,I use jeweler's needlenose,which are smaller & thinner than normal,and have no teeth at all (finer metals will easily shred with toothed pliers).
I am planning on trying to write a book on how to make chainmail *properly*,since the one that I have seen and the websites that show how all do things in really odd ways that take longer to do,and will also make the hands & wrists suffer from C.T.S. a lot quicker.They also don't show all the different "weaves" of chainmail...usually they only show a few of the oriental,persian and european.I only know of one site that shows a piece of the "scaled" chainmail,and that is from my most recent apprentice.
*The* Lunatic Puppy
It wasn't me...It was my *good* twin..
My "inner puppy" made me do it..
[This message has been edited by MacCanine (edited 05-10-2001).]
*The* Lunatic Puppy
