- Mar 12, 2017
@Larrin setting 'em straight on steel yet again!
Thank you sir
Thank you sir
Just out of curiosity, how much black magic are we mixing in while making knives? Is it the "ha, I gave that guy the runs and a wart" level or more like turning the townfolk into newts and uh-oh here comes the Spanish Inquisition?I think folks love love love the idea that somehow they've got a knife with a bit of black magic mixed into the blade that gives miraculous performance.
Nothing wrong with custom blades or most of the folks that make them but once you start to believe the hype it's not good.
Your horoscope says 24% is optimal.Just out of curiosity, how much black magic are we mixing in while making knives? Is it the "ha, I gave that guy the runs and a wart" level or more like turning the townfolk into newts and uh-oh here comes the Spanish Inquisition?
Oh, I see. Thank you.No I'm saying people love to believe in magical thinking like a spiel from some custom builder who can only heat treat knives during a planetary alignment because the extra gravity waves help organize the carbides by height and in alphabetical order.
There's no doubt that super steels are super.
The hype comes into this when someone pretends that what they do is the long lost secret of the Damascus steel or whatever. Instead of selling on their attention to detail of balancing the right steel with the correct heat treat protocol and effective blade shape and edge. In other words; boring.
Jay Fisher is obviously the Guinness World Record holder for making outsize claims but he's not the only one.
Nice article.
I understand that heat treatments are generally considered a trade secret, but I think the lack of transparency regarding expected hardness and toughness (after heat treatment) is a bit concerning. If knife makers and production companies actually sincerely believed that their heat treatments provided a competitive advantage, you would expect them to actually disclose this information.
If you're keeping costs down by running big batches and allowing for 5% of blades to come out at +/- 2 RC in your quality control tests,
1. Time at austenitizing time is based on the steel composition (certain elements move slower than others) the temperature required to get the right hardness level (higher temperature means elements move around more quickly, grain growth may be more rapid), and the thickness of the part. Recommended times are typically found in datasheets.@Larrin Ok, dumb question time. This topic is connected thru several articles so I probably missed the answer (ahh just like in college).
https://knifesteelnerds.com/2018/12/03/cryogenic-part1/
In the first chart of the above article, the horizontal axis is time.
1. How do you determine what time to keep the blade at 1840 degree? 1840 is a rough estimate based on the graph of course.
2. How do you determine the time to temper 1 and temper 2?
Is the time based on the data sheet for the specific metal used?
2. Tempering times are generally a bit more generic, like 1-2 hours per inch of thickness. Some steels and tempering temperatures definitely need 2 hours while others may be fine with 1 hour. This is generally controlled by austenite destabilization which I don't think I can explain in a short space. The effect of tempering in terms of hardness "levels off" after some amount of time, so there isn't much difference really between tempering for 1 hour and tempering for 4 hours.
There are a few reasons that this kind of transparency might backfire.
Let's say you test each blade and issue a certificate. What does it accomplish? Maybe it reassures some customers who are worried they're not getting the "best" heat-treat, but what if they're not satisfied with the number? What if they want it a few points harder it softer?
As far as competitive advantage for publishing numbers, it's only an advantage if you can convince the world that your hardness/toughness is "better" than the competition. That's a big risk to take.
There's also the risk that your manufacturing process isn't as precise as your customers would like. If you're keeping costs down by running big batches and allowing for 5% of blades to come out at +/- 2 RC in your quality control tests, how are you going to explain that to the guy who prefers blades at the top end at 64 and got his at 59? Is the $150 RC 59 blade really substantively "bad" enough to recall? If it is, how many do you test to catch the 5% of "sub-standard" hardness? W
if your grinding process changes your final edge hardness, and you can't even test it reliably but you're happy with performance in other tests?
It's a bigger liability than an advantage, IMO.
The last time around the "people" posting the "numbers" had to walk their claims back down because they were doing a poor job of it.People post HRC test results on instragram, when knife makers aren't transparent or aren't credible. The easy way to avoid negative press is to be both transparent and credible.
Is Chris Reeve Knives loosing business because they published their hardness specification range? Is Benchmade loosing business because they published their hardness specification range? Is Buck loosing business because they published their hardness specification range?
In my opinion, Benchmade's disclosure of their specified hardness range and offer to replace blades that do not meet the specification is exemplary and they should be commended for it.
Actually, yes. They've had a "bad reputation" for under-hardening for a long time. I doubt that the lost performance is a significant factor for their core customer base and might provide some benefits (e.g. easier sharpening/less chipping), but for the spec junkies who care about the hardness and are already used to harder blades it's a turn-off....
Is Chris Reeve Knives loosing business because they published their hardness specification range? ...
If that number is critical for you to buy a knife then there are some makers that will have that for you.
In the meantime some light reading.
https://knifesteelnerds.com/2018/11/12/rockwell-hardness/
