Alex, isn’t this the case and process with steels like Hitachi white? Forging with descending heats towards the end
Yep, traditional Japanese HT was where my question was coming from. : )
I always tell customers and colleagues that flexibility is not a function of hardness but of thickness and most of the times I get that face when someone is not sure to believe you... Now I have a place to send them so they can check by themselves. Thanks Larrin.
Here a 60RC O2 steel filleting knife bent 90 degrees.
Pablo
I wouldn’t necessarily equate descending forging temperatures with descending normalizing cycles. They are somewhat different processes.
Using sufficiently low forging temperatures may very well help with refining grain but it’s not the same as notmalizing. Where is this Hitachi White information?
Take a look at this one, Warren....
https://oldbritva.ru/wp-content/uploads/2016/09/Yasuki-steel.pdf
"To maintain the highest quality crystalline structure, we recommend completing the final steps of forging at a somewhat reduced temperature (750°C/1382°F) and a higher frequency of hammer blows."
Some of that data comes from Hitachi but I’ve never seen Hitachi give forging temperature recommendations. That might have been made up by the company doing that sheet.Take a look at this one, Warren....
Can you scan the datasheet and share it?I do have a data sheet from Hitachi in Japanese. It recommends an initial forging temperature of 850-900 C and a final forging temperature of 750 C for its steels having 1-1.4% carbon. It also does not list a normalizing temperature, which I always thought was interesting (it may simply be because this steel is made specifically for the Japanese knife industry and normalizing was never part of their process; I don't know). For heat treating, it only gives recommended annealing, hardening, and tempering temperatures.
Added: It also lists an absolute maximum temperature of 1060-1090 C for its steels having 1-1.2% carbon and 1050-1080 C for 1.2-1.4% carbon. For forge-welding to mild steel, it recommends that the mild steel should be around 1,100 C and the steel should be 900-950 C. This can be accomplished with kataha (two-layer blades) in a forge that has higher temps near the bottom (such as a coke forge), or it can be done with warikomi (hotdog in a bun weld) blades, in both cases with the mild steel being on the bottom. I am not sure how it can be done with sanmai. Ideally, from what I have seen in Japan, the billet it taken to welding heat and rapidly reduced under a power hammer.
Cold forging is a bit different process: https://knifesteelnerds.com/2019/03/11/cold-forging-of-steel/I find it interesting that a lot of highly experienced Japanese smiths do the cold forging, is that what we are talking about with the White steel? I have an old datasheet somewhere in the shop...
Great article Larrin! Thanks for taking the time to do all of this. Awesome web site too!
The hitachi white I just received from dictum came with this.
Almost identical to Stuart’s
