14" Beaumont/KMG contact wheel
Feedback: +12 / =0 / -0
Rubber, not poly, exact same wheel they currently sell. Bought it a few years ago, but it's basically new, I've literally only run 2 or 3 fine grit belts on it, to grind a couple of long curved swedges. Maybe 10 minutes of total grind time.
I just don't need it, I don't do hollow grinds, and I've got a 10" wheel. Its little dirty, and some paint scratches on one side from making contact with other tooling on the bench, surface rust on the steel side of the hub, cosmetic only, rubber is perfect.
Doesn't have a riser, which isn't necessary with most grinders, and is easily fabricated.
$415 shipped CONUS for the wheel only (Beaumont price is $482.90). If you need a tooling arm though, I may be able to provide one, depending on what you need.
I'll throw in the 1.5" solid square aluminum tooling arm it's on if anybody needs it. If you need a 1.25" one, I'll drill and tap it for you if you provide the aluminum.
