Well if it is from Sandvic then going by number progression it would probably be a slight upgrade from 13C26.
Plus, when "N" is used in the name of a steel type it usually denotes "Nitrogen", which seems to be quite beneficial to most steel types so far.
Nitrogen is the primary hardening agent in H-1, and is used in various other steel types to improve corrosion resistance, amongst other things.
I wonder if Kershaw got Sandvic to produce a special mix for them that would give better performance and still work with blanking machines?
If this is anything close to what I think it is we are in for a real treat.
The 'N' means nitrided, right? Is that what you mean?
I looked up a lot of different things last night and remember coming
across something like that. Nitrogen etc....
mike
Whenever I see "Nitride" used it refers to a coating, when letter designations are used in the name of a steel type it often refers to an added element.
Though adding Nitrogen to steel could be considered "Nitriding", I'm not a metallurgist so I can't say for sure.
14C28N was then created and designed for us. 14C28N is exclusive to Kai USA/Kershaw Knives, and we are very excited about bringing it to market.
Ok, you can all start asking more questions now.
Has production changed from 13c26 already?
14C28N will have similar performance properties to 13C26.In testing where would it be located for:
Example: 14C28N has better edge retention than S30V. etc...
Hardness
Edge Retention
SureWill you offer it in Satin finish, DLC etc?
YesWill this new Kai steel replace all apps currently using 13C26?
More towards 13C26Pricewise, how does it compare to 13C26 and S30V?
Can't wait.Ok, that's enough for now.![]()
Can't wait.
Ok.
Mitch Murphy: How fast does this thing go? Does it have automatic transmission? Does it have four-wheel drive?
Airport Driver: Look, I told you before, kid. Don't bother me. Now beat it.
mike
