Larrin
- Jan 17, 2004
You speak to me as if I am ignorant which you should know by now that I am not. I have provided the numbers and that is all, and said only that they clearly show S30V has better toughness, and I have not said that S30V will show vastly superior toughness, or the opposite, that it is an unnoticeable difference. To tell people that I am feeding people false opinions on a subject that I have provided only numbers for is ridiculous. As for transverse toughness I did not say that S30V would be 4x less likely to break or chip with a side impact, only that S30V gets 4x better in transverse toughness which is effective in side impacts to a knife. To say that 4x better in transverse toughness would directly translate to 4x increase in a knife would also be ridiculous, as there are other factors. However, I cannot argue with Crucible's testing that an isolated impact to the side of a bar of steel has 4x greater toughness with S30V than 154CM, because I am familiar with Crucible's testing methods, and their methods of presenting information in data sheets, and I believe that most information in them is correct, as long as you look at the information for what it is.Larrin, I want to note a few issues here which have to do with experimental data in general which you have a really skewed viewpoint of which isn't helped by the people feeding you information. All experimental data is prone to errors in measure, this is actually a fundamental law of physics, any observation introduces uncertainty. Impact tests are generally around the 10% level assuming Hitachi's data is competent.
Now add to that the batch data composition, look at the tolerances in the steel and see how much you would expect that to effect the results. Now look at effects in heat treating, I am not talking about different recipies but just general time and temperature variance for the exact same scheme. Now if you add all of these up would you ever consider 16 vs 25 ft.lbs was significant.
No, they are not which is why Crucible's origional assertion that they are all the same is valid because they are not significantly different. You never compare experimental data using a simple equality, you always have to use ranges.
Larrin you are supposed to look for them. This is science not religion. You don't accept something because someone specific says it. That completely destroys all credibility in the arguement and produces nothing but hype. You are supposed to ignore the speaker, look at what they say, see if it makes sense, check with other sources. If they are selling something then at the barest minimum look at what is said by those that compete with them and the unbiased evaluations relevant to that field.
Just look at what is claimed, L6 for example is about 4x the izod toughness of M2 (actually less at common knife hardness for each). Forget that it is said by whoever you spoke to you as are never supposed to give that any consideration anyway. If John Smith, a complete novice knife maker asked you he wanted a stainless which was related to 154CM in toughness as L6 was to M2. You would really suggest S30V?
-Cliff
