154 Patina?
Uncle Timbo
Hey you all, short and sweet, would 154 take a forced patina like from mustard or vinegar?
Thank you ahead of time.
BTW, if any of you remember me, I gave up on the D2.
if d2 wouldn't, id expect 154cm to hold out even better, but ive never tried. just know how corrosion resistant 154 has been in my use of it.
Thanks Mr. Monkey. I recon I'd better just stick with carbon steel if I'm after a quick patina.
yes Sir.
if that's your goal, carbon will make ya a lot happier on results, i'd imagine.
I would think it never would take a good patina. I have a couple and used one camping for several days cut several packages of hotdogs and several packages of smoked sausages and some hamburgers and a few packages of bologna. I wiped it down after each use with a dry rag but have not made it to a suitable water source to wash it yet and still have no patina issues
The irony about discussing 'patina' on stainless steel is, the 'patina' formed will be essentially invisible anyway. When stainless steel oxidizes, it's oxide is chromium oxide, which is essentially colorless (clear), unlike the iron oxide (red rust or black oxide) formed in the oxidation of non-stainless steels. This is why stainless steel never seems to be altered in color, when exposed to and reacting to the things that ordinarily would rust (or truly 'patinate') a non-stainless steel. The darkening seen on 'patinated' stainless blades is only a result of fairly deep etching of the steel. It's not really the oxide making it look that way; the effect comes about in the shadows created by the microscopic pits in the etched surface of the steel. And because it's etching, and not an oxide, that implies something far more chemically aggressive is needed to do it. Kitchen-use vinegar (5% concentration) won't generally be strong enough to do it. This is why more aggressive caustics, like ferric chloride, are usually suggested for 'patinating' (etching) stainless steel.
David
