154CM (and ATS-34, same steel by a different name) are usually pretty rust-resistant. But, any steel can rust. The frequently-touched area near the thumbstud probably accumulates more dirt/sweat/grime which, if left alone, can cause rust issues. Especially sweat, which contains salts, and will accelerate rusting. Just make sure to keep it clean & dry after handling it. Thumbstuds can sometimes get in the way of a rag or whatever's used to wipe the blade, so the seam area at the base of the stud might getted missed. Scrub that area with some WD-40, isopropyl alcohol (rubbing alcohol) or even Windex, which will do a lot to wash away skin oils (again, salt) and anything else that might accumulate & trap moisture & salt there. You might even consider polishing that area a bit. Polishing can close up some of the pores in the steel, which might otherwise trap moisture & other corrosive stuff. Certain 'textured' blade finishes, like bead-blast in particular, are notorious for trapping moisture & causing rust on stainless blades.
