I'm a newcomer to the Blade Forums. I'm considering purchasing a paper wheel sharpening system. I've been looking at threads here and various websites dealing with these systems. Apparently there is some differing opinions about shaft RPMs. The inches per second of grinding surface delivered varies a great deal between the RPM and the wheel diameter: 6" - 542/1084, 8" 722/1445, 10" - 903/1807 ips at 1725 and 3450 RPM respectively. Is there an ideal? I'll be making up something with a dual shaft arbor so I can deliver any reasonable speed by varying the motor pulley diameter. I know that experience and material properties both play a large roll, but there must be a range where heat build-up versus stock removal makes the most sense.
