Generally, you want to remove as much as you can pre-heat treat. The only time I wouldn't pre-grind would be if there was going to be significant distal taper, as its too difficult to keep it straight in quench. I plate quench, and still find that full thickness might require some tweaking to get straight, but it's not that difficult, usually. Plate quench to @ 500°, remove from foil and straighten, then water quench. Dry off and into liquid nitrogen.
Good luck!
