180 grit mirror polish
bodog
BANNED
I'm posting this here because a lot of steel nuts don't go into maintenance and tinkering. I posted there because a lot of stone gurus don't come here.
WTF is going on?
I normally use congress ruby(alox) and moldmasters (SiC) stones or cheap chinese stones. They usually work well. I've sharpened S110V at 59 RC. I've sharpened 52100 at 64 +/- RC. I've sharpened a lot of different steels and both work about the same.
The Chinese stones glaze a little faster but with water or oil they work fine. They wear just a little faster and cut a little faster than the Congress stones, normally.
I have sharpened vanadis 4E at 61 RC with both sets with no trouble.
I now have a cpm 4V blade at 62-63 RC I'm trying to sharpen. I am able to cut it with the Congress ruby stones at 220 grit, albeit slowly.
I swapped to a 180 grit chinese stone to work it a little faster. The stone is barely taking any metal off. But here's the deal. The 180 grit is leaving a close to mirror finish. 180 grit.
I scrubbed the stone, resoaked it, and tried again. Basically the same thing happened again. It feels like it's skating on the edge. The Congress stones feels like it's doing the same but a little less and leaving what I'd consider to be a normal 220 grit finish.
With Vanadis 4E being so close to 4V and them having very similar Rockwell hardness, why is 4V acting this way with stones that readily cut the vanadis steel?
I don't believe it's overly hard, the other day I was beating the 4V knife through nails and metal pallet straps with barely any chipping (about .016" behind the edge). If it wasn't tempered (leaving it at full hardness) I would have broken the knife because I was beating it so hard with a hammer.
I worked the surface of the adaee stone with the 220 grit ruby stone and no change. Scrubbed the surface with scotchbrite and dish soap under hot water. The normal stuff. No difference.
I assume the Chinese and ruby stones are both alox so I don't ever consider them to be fast cutters but when used on most knives I've sharpened they've gotten the job done, leading me to suspect something is going on with the steel.
Any ideas?
Sounds like it's burnishing the steel instead of abrading it. Just a wild a*s guess. Increase pressure, see if you can get the stone to release some abrasive.
