The blade stock is 3/16", which worsen the blade light feel of an 8" blade (serious survival choppers begin at 9.5"-10", and should be a full 1/4" stock): That being said, the Randall Model 14 is misleadingly claimed to be 1/4" stock, but is in fact also mostly 3/16" (tapers a bit thicker, but only very close to the handle), and with the nice-feeling finger grooves believe me when I say this comfortable seeming Randall handle makes it a spectacularly uncomfortable chopper...: The form-fitting handle means the shock has nowhere to go... A good slicing knife but the worst chopper in that size range I have ever experienced... The Model 14 is also claimed to be 7.5", but is usually 7.4", so I would say a true 8" blade is definitely better.
If your alternative choice is the Randall Model 14, and the edge holding turns out to be similar between them, I would definitely say this knife offers more than the Model 14... Even if the handle feels worse in initial handling, under hard use it cannot be worse than the finger grooved Randall handle (which I still love because it looks and feels so nice, as long as you are not chopping with it).
I did not realize the 1911 was an 8" knife: I assumed 7"... It definitely looks like a serious design, but it would be better with 1/4" stock. Still a very functional knife, which fully fills the Spec Ops sheath for once... The Spec Ops is a $60 value, and I would get it for all my Randalls anyway, so the 1911 is a really competitive knife with a Randall of similar size I would say...
And it offers a really nifty handle feature at no loss in strength, quite the contrary...
The knife's weight is a rather imposing 21.5 ounces (A 10" Lile Mission is around 18-20 ounces), which I suspected from the strong construction, and is a significant drawback for a meager 8 inch blade... This could be an exaggeration due to the included Leatherman tool in the handle...
The 7.4" Randall Model 14 is around 14 ounces, the Model 18 around 12 ounces, so 21.5 ounces is a significant drawback for an 8" blade only 3/16" in thickness: These are numbers that suggests a very blade-light feel. The pointy tip profile (which I am sure is still quite strong in cross-section) also contributes to this, so this knife has a
very strong fighting-style feel to it, rather than the claimed survival style of balance: Not much effect in actual outcomes, but something to consider before being disappointed by the feel on delivery... The Randall Model 14 has the same handle-heavy balance anyway, but very likely less accentuated.
Gaston
