- Aug 4, 2001
Maraging steel alloys are twice as hard as stainless steel and 35% stronger than the hardest titanium alloy.
... is two times harder than stainless steel and 85% harder than pure titanium.
High strength would make a blade much more resistant to general damage and bending, and I do believe that, for any given size, the maraging steels represent the strongest alloys available.
So, for a knife that will be "abused" it might be worth the tradeoff in hardness for the massive gains in toughness?
Alan-B said:Looking forward, please, excuse me for my bad English.
Also, i prefer use metric system.
Maraging steels - is one of the my main interest and i have some information about them (mainly, about Russian steels and alloys).
If you are interesting in higest hardness, you may archive one using follow steels:
Up to HRc 60 on 18% Ni, 10% Co, 4% Mo, 1.8% Ti steel (close relative to Vascomax C350 and similar steels). Using cold deformation and low temperature of aging (440-460C) you can get more, than HRc 60.
Up to HRc 63-64 on 12-13% Ni, 15-16% Co, 10-12% Mo, 0.8% Ti steel (close relative to Maraging 400 grade). Using cold deformation and low temperature of aging (440-460C) you can get HRc 65.
Up to HRc 65-66 on 8% Ni, 18% Co, 14% Mo, may be 0.8% Ti steel (close relative to Maraging 450 grade). Russian EK3 alloy, developed in in 70's, may get up to HRc 68.
And, finally, some W-Mo-Co alloys can show hardness up to HRc 70, but they have to low plasticity and impact toughness for knifemaking.
In Russia developed stainless maraging steel EP853, (11% Cr. 10% Ni, 2% Ti)/ It can be hardened up to HRc 59-60 (may be, 61).
On these days i must get 2 samples of blades, made from custom maraging steel. Estimated properties: HRc 64-65, tensile strength around of 3000 MPa, elongation approx 4%, area reduction approx 20%, impact toughness approx 0.35 MJ/m^2. First results will appear on next week.
