- Aug 5, 2005
Mike Kerins said:Trax,
It was Lizard1123...
Mike - we keep leapfrogging each others replies...
Here's an interesting stat -
Winning Bid: Jan-16-06 10:32:50 PST
Ended: Jan-16-06 10:33:03 PST
13 seconds...
By sniper standards that's pretty slow.chickentrax said:Mike - we keep leapfrogging each others replies...
13 seconds...
Oops!!Scott Hartman said:Mike, I think you clipped me by a couple seconds on that 110 last night![]()
You may be right Will, I usually consider the possibility of sniping when last second bidding is done on a regular basis. But then again I may be unfairly assuming it.WilltheBarb said:13 seconds sounds like a human bein' to me. I don't think it's snipping if a person hits submit.
Mike Kerins said:I don't have any production figures, but I believe it's the "etched" first version where they etched Buck onto the blade that is really scarce and hard to find.
The Last Confederate said:I'm refering to the stamp on what we would consider the "back" side, the opposite of where new 110's are stamped, with the stamp running horizontal with the blade spine.
The Last Confederate said:Yup, nice pic' trax!
I'll tell you one thing, that 110 with a "texas toothpick"-shaped blade looks a damn sight better...closed....chickentrax said:<coff,coff>...It's from that auction...![]()
...I thought Dave might appreciate it...![]()
Yep! It looks great as long as you don't show the blade!geothorn said:I'll tell you one thing, that 110 with a "texas toothpick"-shaped blade looks a damn sight better...closed....
GeoThorn
The Last Confederate said:Was nice of you to put it up for Dave.
That could be but in this case, the seller even admitted that the blade had been sharpened and the blade profile reduced significantly. I believe that the blade profile, while longer and narrower than contemporary versions, would still have the curve in the blade as it meets the drop point. Sharpening will tend to remove that curve and I think that is what happened in this particular case.LFH said:I thought I saw somewhere , that some of those first blades were thin like this one, to start with.
chickentrax said:The least I could do. A Codeine jag can really affect your ability to type...![]()
Mike Kerins said:That could be but in this case, the seller even admitted that the blade had been sharpened and the blade profile reduced significantly. I believe that the blade profile, while longer and narrower than contemporary versions, would still have the curve in the blade as it meets the drop point. Sharpening will tend to remove that curve and I think that is what happened in this particular case.
