Almost complete with my first knife build. The blade still needs sharpening and I am still working on the sheath and etching the makers mark but wanted to post photo's and ask about this hamon line. ANY FEEDBACK WELCOME... For any of you trolling these forums and thinking about getting started, this knife was built with cheap harbor freight tools and a modified one-brick forge. I figure about a $350 investment in tools and materials to get started.
Got hooked on this hobby/obsession after listening to a radio segment on NPR this spring. The idea festered for a few months and after lurking in these forums for a while I decided to give it a try. This knife was about 3 months in the making from shop setup to completion. I have 2 similar blades from the batch awaiting handles (both w/o the tacky gut hook). Anyway, here are the specs.
Blade: 1095 with oil quenched hamon, hand polished to near mirror finish.
Grind: Flat
Handle: Whitetail antler with leather and green spacer
Bolsters and pins: Nickel Silver
Knife is for a co-worker who wanted a knife made from his hunting trophy. He demanded the gut hook.... :grumpy:
Here are the pics.
I am not entirely pleased with the Hamon. It is a very distinct line with some interesting coloring when viewed in different light angles. However it is more distinct and defined than many of those you see in other photos. Those may have been water quenched Hamons. This blade was oil quenched to the folliwng process.
1. Annealed the blade, soaked at ~1550 for about 10 minutes. Shut the forge off, closed the openings and let the blades sit overnight.
2. Ran the blades through 6 thermal cycles to reduce the grain size. Started at 1475 and soaked the blades for about 5 minutes at temp, removed and put them on a scarp of steal to air cool. Repeated 5 more time reducing the forge temp by 25 to 30 degrees each time.
3. Clay-ed the blades with Rutland furnace cement about 3/16 inch thick.
4. Heated blades at 1475 with a 10 minute soak to let things go into solution.
5. Quick quench in oil (canola) with a back and forth motion.
6. Tested hardness with a file.
7. Tempured at 375, 3 times. Clay was still attached during first cycle, did not want to risk a cracked blade by banging off the clay from the stressed steal.
FYI this was a 2nd batch of blades. The first batch was brine then oil quenched but the hamon extended into the cutting edge. These blades cracked when I tried to re-heat treat for a new hamon. At that point they had been fully ground. I've since learned to pre-etch after a 320 grit sanding to check the hamon. After that expereince I decided to go with a full oil quench to get my first successfull blades.
QUESTION: Is this a "NORMAL LOOK" for an oil quenched Hamon? I suspect that clay thickness, forge temp and quench medium all play a part but would welcome any discussion on how that played in this hamon. Also welcome any comments on my first completed knife.
Barry
Grind: Flat
Here are the pics.
Barry
