2 AR500 Body Armor plates FSOT
Feedback: +10 / =0 / -0
Greetings,
I have two brand new, never carried or used AR500 Trauma Plates, these are the flat ones, in a vest you can't tell a difference.
Straight from the website: Here is the website for them: http://www.ar500armor.com/index.php?dispatch=products.view&product_id=29778
Manufactured from NIJ Certified Ballistic Plate
AR500 Armor body armor is designed for maximum coverage of vitals while allowing the operator to shoulder their weapon comfortably. Our AR500 Armor Plate will fit in all plate carriers capable of accepting 10"x12" plates, slim 1/4" thick profile.
The AR500 Armor ASC Trauma Plate is AMBIDEXTROUS, suitable for both Right and Left handed shooters. The plate has no weak side, and can be positioned accordingly to take the Advanced Shooters Cut.
Line-X Protective Base Coat: All AR500 Armor Body Armor now ships with a Line-X Protective Base Coat which provides a level of spall and fragmentation mitigation properties and superior chemical, wear, water, and harsh condition resistance. Also features a hand applied high traction surface helping the plate stay in position. The new Base Coat truly takes our armor to the next level!
Rating: AR500 Armor Trauma Plates are stand alone, multi-hit capable, and bench tested to the same armor rating as Type III. Type III Armor will defeat rifle rounds up to 7.62x51/.308 @ 2780 ft/s.
Recent testing provided good results against Federals XM855/SS109 Penetrator Round (Green Tip 5.56). We fired 7 rounds at 15 yards within a 2.5" group and experienced no penetration.
Size: Our standard plate is 10" x 12" Our plates will fit most carriers on the market and are designed to provide maximum coverage without expensing mobility. Unlike many other trauma plates on the market ours allow you to shoulder your rifle comfortably and allows for various positions. One angle on our plates is cut deeper than the other; this is designed to accommodate the butt-stock of your rifle. We found that the standard cut or other ergonomic cuts interfere with properly seating the stock in your shoulder and force for a stock to ride high on your shoulder. The Steep, but not deep angle gives you the best of both worlds. Maximum coverage of your vitals and better ergonomics while shouldering your rifle.
Weight: Each plate weighs in at only 7.5lbs.
Maintenance: Our AR500 Armor Trauma Plates do not have a limited shelf life. No special handling is required outside of common sense; our armor is built to last. AR500 is durable and much less fragile than ceramic when it comes to general handling, storage, and maintenance.
Looking for $120 shipped USPS Priority, paypal or money order. Ships same or next day. Email me for fastest response: zombcrew@yahoo.com[/SIZE]
