Thanks. Yes it is 3/4" stock holding the tubes together. The 30lb gas spring has about 3.5" of travel, which is just barely enough to get belts on and off without moving the tool arm in and out.
The aluminum was bought from metals online. They usually have 25% coupons floating around.
What used to take me the most time (and the part I dreaded the most) was polishing the end cuts of the aluminum. On this grinder I used a roughing end mill bit and simply used that to finish all the cuts. That was much better than polishing and I think it looks just as good. The jeweling, although it may look time consuming, actually is fairly quick. I jeweled every piece on this thing in about 20 minutes total. It is actually covers up a bunch of nicks etc.
Mike I had not planned on a wet setup on this one, just like a rust free unit and a material that is fairly easy to work with. Thanks for the tip on the anti seize. I had not thought about that, but did use locktite on everything.
