- Feb 18, 2011
For sure ESEE 5 and 3, the 3 is a great slicer and as for the 5 I believe it speaks for itself.
In what situation would a HEST be better than an ESEE-3 in the PIs? As I think our weight concerned friend should be think of one of those and an ESEE-6.
Thanks for all the replies. Currently, I'm leaning towards the ESEE-3. I just don't trust 2.88 inch blade. On the other hand, I'm torn between the 5 and 6. The 5 seems so redundant and heavy, but only when paired with a bolo or kukri (which happens only on the longest undeveloped trails), i may miss some of its utilitarian value especially when i don't take the larger blades (which is often the case).
Does it matter that i've fallen on these "adventures" several times, wrecking several hiking poles and snapping a thin bolo? (my record is 17 falls/and slides in one day on a steep and muddy trail, and a face first 20ft dive down a not so steep cliff face in another trip)
So, there'll be times when I'll use the knife to dig and do light prying. And others when i'll try to use the knife to find purchase or leverage along a trail.
The bolded section would make me suggest the 5. The extra thickness and sabre brind will make it easier to dig and do light prying....it will hold up better and be stronger in that area. Some people call it a 'sharpened pry bar'....and there's definitely a good reason to.
The 6 can be used to dig and do light prying, but it is thinner and I'd want a 5 in that situation....depends how often you are going to need your bigger knife to be built like a tank.
I love the 3.
The bolded section would suggest to me to not use a knife.
