2 Kershaw Ripcord 3200's 1 with belt sheath 1 with belt clip NIB $80 Each or both for $150 , Prices are all in to your door. These are no longer made. They have been handled and looked at but not used or carried. These were made in 2007.There are utube vids. about these. Email me at ryan12473@aol.com it pops up on my phone. Info and specs. at bottom. 99% Marks that looks like scuffs or scratches wipe off, dust and dry oil.
Kershaw Knives
DISCONTINUED Kershaw 3200 Ripcord
Be the first one to write a review
$106.22 Reg. Price $169.95 You Save $63.73
KERSHAW 3200 RIPCORD - If you've got a challenge to face, pull the Ripcord. The Ripcord offers a unique, patented design that provides the strength and stability of a fixed-blade knife, yet stores as compactly as a folding knife. The key is Kershaw's "Out the Front" (OTF) design. With OTF, the blade slides out the front of the handle into a secure, fixed-blade position. A convenient belt sheath doubles as the OTF deployment system. The knob in the sheath engages or disengages the locking function. Simply grasp the handle and pull straight out of the sheath and the blade will deploy in a locked fixed-blade position.
KS-3200
With OTF, the blade slides out the front of the handle into a secure, fixed-blade position. A convenient belt sheath doubles as the OTF deployment system. The knob in the sheath engages or disengages the locking function. Simply grasp the handle and pull straight out of the sheath and the blade will deploy in a locked fixed-blade position. To retract th blade, place the tip into the sheath, set the handle onto the knob and slide back into the sheath. The blade is Sandvik 13C26 stainless-steel for strength and superior corrosion resistance and edge retention, while the Tungsten DLC coating enhances performance and looks good doing it. The Ripcord's handle is lightweight anodized aluminm with Trac-Tec inserts for an incredibly secure grip even in extreme conditions.
Specifications
Steel: Sandvik 14C28N stainless steel, DLC coating
Handle: 6061-T6 anodized aluminum with Trac-Tec inserts
Blade Length: 3 7/16 in. (8.6 cm)
Closed Length: 4 3/8 in. (11.1 cm)
Overall Length: 7 13/16 in. (19.8 cm)
Weight: 4.2 oz.
Kershaw Knives
KS-3200
Specifications
Weight: 4.2 oz.
