(2) MARATAC AA Flashlights from County Comm
Feedback: +23 / =0 / -0
These are two flashlights I have as spares. The hard anodized (grey) Rev 2 AA has minor rubbing wear on a very small portion (see pics) but is otherwise in fantastic condition having seen nearly no use. The Tactical Personal Flood had a battery put in it but was never used, and is Like New in Tube. Please post here then PM me for Paypal information.
From the County Comm site:
MARATAC™ TACTICAL PERSONAL FLOOD ( TPF ) AA LIGHT (Black) - Asking $30 gifted/shipped to CONUS.
The Maratac™ AA Aluminium flashlight was so popular, we had it made in a right angle varient. The same great light in a right angle form factor, featuring a 105 degree beam of projected light for increased field of use and a glow in the dark reflector. Checkout this AA powerhouse now with many new upgrades:
Specifications:
• Length: 2.78"
• Diameter: .76"
• Weight 19.3 Grams / .68 Ounces without battery ( Incredibly lightweight )
• Black Hardened Steel Pocket Clip ( Easy to clip onto a hat, MOLLE gear or shirt pocket )
• Glow In the Dark Built In reflector ( Easy to find in the dark )
• LED Type: Cree G2 Emitter ( High Output ) with a life span up to 50,000 hours.
• Flashlight body is made of Aircraft Grade Aluminium
• Stainless Steel ring around the dome lens for added durability
• The dome lens has been treated with a AR (Anti-Reflective) coating.
• Proprietary circuit design features reverse polarity protection and runs off of one AA battery that provides 3 levels of brightness ( Low /Medium / High).
Using A Single Duracell AA battery we got the following results:
• Low Mode, 5 lumen output for upto 100 Hours ( Diffused Light )
• Medium Mode, 40 lumen output for upto 7 Hours
• High Mode, 135 lumen output for upto 90 Minutes
• Price $38.95 Retail
• Limited First Run
MARATAC™ AA FLASHLIGHT REV 2 - Asking $25 gifted/shipped to CONUS.
Rev 2 Changes :
- CREE R3 Emitter ( 55 % brighter )
- New Mode @ .25 Lumens ( Lunar Low ) Perfect for close up inspections to avoid distractive flashback. Once your eyes acclimated this is more than enough light for reading or walking around. Lunar low is more useful than you think.
- Stronger Clip
- Deeper Orange Peel Reflector ( tighter brighter beam )
- Comes with Silicon Dome
- Slightly larger keychain look for larger cordage
Specifications:
• Length: 2.99"
• Diameter: .70"
• LED Type: Cree R-3 with a life span up to 50,000 hours.
• The reflector is aluminum alloy.
• Flashlight body is made of aircraft grade aluminum covered with Type III Military grade anodization.
• The lens has been treated with a AR (Anti-Reflective) coating.
• Its proprietary circuit design features reverse polarity protection and runs off of one AA battery that provides 2 levels of brightness ( High / Lunar Low ).
• Lunar Low Mode, .25 lumen output for 225 Hours
• High Mode, 125 lumen output for 90 Minutes
