GrReaper,
As far as the edge angle; your call. If you want slicier, go with 30 Deg. Harder use; go 40 Deg. Edge angles can be anything the user/sharpener wants them to be.
Concerning the Steel: It is the same; AUS 8(A). The "A" denotes Annealed but if it comes in strip form (which is what all blade steel comes from) it is annealed. Both terms get used interchangeably.
The AUS steels are from Aichi Steel company in Japan. A great Martensitic stainless steel. Pretty good performance in a moderate price.
As a general rule of thumb: Aichi AUS 4 equates to AISI 420HC, AUS 6-440A, AUS 8-440B, AUS 10-440C.
Hope this helps.
Best Regards,
Paul Tsujimoto
Director of Engineering
Ontario Knife Company
Another question, is the RAT2 ground at the same angle as the RAT1 at factory?.
