2 questions
1. is there something I can do to keep to keep the origional metalic look of the khukri blade to avoid it getting a patina? Like if I want to display it?
2. Can I chop down trees with a 15" Sirupati?
About the patina:
Khuks are made from Leaf Spring, wich is high carbon steel. Treat it as any carbon steel.
Mineral oil do the trick. I use baby oil because it's cheap. I also like the irony of the little baby smell caused by my knives.
I know, I'm weird.
One more question....I have a conformation number for the khukri I ordered over the weekend - is there a way I can check on the status of the order online?
I'm not sure what kind of number. It is a long combination beginning with letters and then containing numbers. begins with yh....
hmmmmmm... not sure on this one.
im sure others will chime in with suggestions :thumbup: :)
if anything, try dropping auntie yangdu an email at HIMIMP@aol.com if the order was placed with HI.
im sure.... actually i am positive that she will be able to assist you :cool:
That's the confirmation number generated from the online store. no way to track it unless you call Yangdu but you receive it soon unless it's intenational or she didn't have it in stock.
From what I've read here and my own experience, usually within a week even international.
If you plan on using it to chop wood and sharpening it, you will not keep the mirror finish, it will get scratched up. Better off taking some 600 grit sandpaper and a green scotchbrite and giving it a nice satin finish, which will hold up a lot better with use. Then just wipe it down with a mineral oil or wd-40 soaked rag after each use and it will be fine.
Yes, I received my khukri and it is all that they said it would be and more. It's very beautiful and I am happy with it. I guess I was just over anxious to get my new toy : )
If you use the kukri you will scratch the finish no matter what you do. The only way to restore it to pristine is with a buffing wheel and white buffing compound.
If you want to keep the blade from ever getting a patina you can periodically use Flitz or Simichrome to polish any patina back off the blade.
I had a brand new Marble's Woodcraft and an ndn friend of mine wanted to dismember the wings from a wild turkey.
The first cut turned the steel a very dark charcoal color and Flitz took it right off with very little effort when we were done.
You can put a nice satin finish on the blade with sandpaper or a Maroon Scotch-Brite pad. Just be careful along the edge because if you rub along the edge proper it will definitely dull the blade. I generally rub the blade lengthwise right close to the edge and if the edge needs cleaned up I'll rub from the direction of the spine to the edge being careful to not drag the Scotch-Brite around the edge proper so as to not dull it.
IMO the satin blade looks better than the polished blade and very few of my kukris have the polished blade anymore.
But I do have a dedicated buffer along with the one on the shaft of my Grizzly Knife Grinder. I dress it with tripoli or jeweler's rouge to get the heavy scratches out and then use the other two buffing wheels on the other motor for the white and green compounds.
A 15" Sirupati is not a real chopper but the 20"+ Sirupati can do an excellent job of chopping as can the 22"+ Chitlangi.
My large Chitlangi is duel fullered and it's fairly light but it cuts like a much heavier kukri as does my 18" BGRS.:thumbup: ;) :D :cool:
I would be interested in seeing a picture of a satin finished blade.
its basically a much cleaner refined villager finish :)
hmmmm, i guess i would compare it to what you would normally see in stainless steel countertops lol.
orrrrrr the un-shiny side of aluminum foil....
Simichrome
by Yvsa
what about TsimiChrome?:D ;) :rolleyes: I don't like that polish myself due to the duck guano he adds to it---works great but the stink is terrible. I also have the urge to find a one legged woman and crawl into the earth.
Boy is this reply going to confuse our newer formumites:D
