I though this would be great pattern to continue making. Blade steel is 1080 plus from Alpha Knife Supply, a great knife steel with a little bit of chromium and vanadium. I used chain ring bolts for added strength and visual appeal. The handle is natural canvas with a rough sanded finish for extra grip. $170 shipped to your door with a made to order leather sheath and if you dont need the sheath $120.00.
Handle- 4.7"
Blade- 5.2" edge 4.65" .160" stock
Full Flat Grind, Hand sanded satin flats, machine satin bevels
Handle material-Natural canvas Micarta sanded and contoured for grip , G-Flex epoxy with aluminum tubes for pins and lanyard, chain ring bolts added
blade Steel- Alpha's 1080 Plus high Carbon steel, edge quench
In house heat treat and temper.
http://i590.photobucket.com/albums/ss349/jr19703/P1100372.jpg[/IMG
[IMG]http://i590.photobucket.com/albums/ss349/jr19703/P1100373.jpg
Hunter
Handle- 4.5"
Blade- 4.2" edge 4.5" 1/8" stock
Almost full flat grind, hand sanded satin flats, belt finish satin bevels
Handle material-, Nice Cocobolo wood sanded to 1500 then buffed, G-Flex epoxy with Brass pins and lanyard tube
blade Steel Aldos 1084 Carbon steel, edge quench
This knife will come with a natural leather wet formed sheath. $165.00 shipped or without for $120.00
Handle- 4.7"
Hunter
Handle- 4.5"
