2 small Maratac flashlights (SOLD)
jeepin
Feedback: +404 / =0 / -0
I have 2 brand new Maratac flashlights I’m selling as a pair.
One is the AAAx2 Extreme penlight, the other is the Peanut Beast flashlight.
The Peanut Beast comes with the charger, lanyard and rechargeable battery.
Peanut was $39.95, the penlight was $44.95 then tax and shipping on top of that.
I’m asking (SOLD) shipped for the pair with PayPal friends and family, Zelle, or Venmo for payment.
Pm or email me at mashguy4077@yahoo.com if you want them.
Pen light-
New - > Cree XP-G3 LED For 2021 - A larger domed Cree emitter with more power than the old G2
Slightly Wider Beam With Improved Color Rendering
+ Lunar Low 1.5 Lumens
CAGE: 5VKB6 ( NSN: Pending )
Glow O-ring Around The Reflector ( easy to find in the dark )
Black Powder Coat Pocket Rotating Pocket Clip
The Maratac™ Inspection AAAx2 Extreme LED flashlight is made to be both tactical and practical. The light is straightforward to use and has friendly ergonomics. The Maratac AAAx2 Extreme features an advance Cree XP-G3 LED for greater brightness and efficiency.
Medium 45 Lumens / Low 1.5 lumens / High 425 lumens mode brightness control (Simple 3 mode switching)
Operation:
Press and click the back thumb switch to turn on the light into Medium mode. Lightly press again for Low mode and once more for High. Press and click anytime to turn the light off.
Peanut-
IP-68 BASED ON TEST CONDITIONS FOR SUBMERSION IN UP TO 1.5 METERS OF FRESHWATER FOR UP TO 30 MINUTES.
THE SMALLEST & BRIGHTEST FLASHLIGHT WE MAKE!
CHECK OUT THIS "BRILLIANT" POWERHOUSE.
JUST CHANGE TO THE CHARGING BRASS ( BUTTERY SMOOTH ) HEAD TO CHARGE THE LIGHT AND YOU'RE ALL SET TO KEEP ON TREKKING.
CAN BE CHARGED FROM WORK, HOME, LAPTOP, USB BATTERY PACK....
SPECIFICATIONS:
LENGTH: 2.1" DIAMETER: .94"‚
WEIGHT: .75 OUNCES - WITH BATTERY
BATTERY WEIGHT 3 GRAMS
COMES WITH EXTRA O-RINGS
LED TYPE: OSRAM KW 6500K COOL WHITE LED WITH A LIFE SPAN UP TO 50,000 HOURS. ( NEWEST & BRIGHTEST EMITTER )
SMOOTH DEEP REFLECTOR FOR A SMOOTH EVEN BEAM
RECHARGE TIME IS 30-80 MINUTES - DEPENDING ON CHARGE RATE SOURCE
THE REFLECTOR IS ALUMINUM ALLOY.
FLASHLIGHT BODY IS MADE OF AIRCRAFT GRADE ALUMINIUM ( BUTTERY SMOOTH )
BATTERY IS 10180 LITHIUM CELL 80MAH
THE LENS HAS BEEN TREATED WITH A AR (ANTI-REFLECTIVE) COATING.
ITS PROPRIETARY CIRCUIT DESIGN FEATURES REVERSE POLARITY PROTECTION AND RUNS OFF OF ONE 10180 BATTERY
