Hi Polock
this is DaQo'tah
I read your post, and it got me thinking about something that I tried and failed at, yet have been thinking over why I failed...
Last year, I had a blade of a 52100 steel knife all heat treated and tempered and finished sanding and buffing on.
I next wanted to place a handle on it,,I drilled out the oak for the hidden tang, when I read some posts on Blade Forum about adding some brass pins to a hidden tang handle.
They said to place the handle into position over the tang, then drill into the wood on one side untill you bump into the steel. You try to drill into the steel just a little bit , just enough to make a mark. Then slide off the wood handle and drill into the steel at the place you just marked.
Well...I decided to try this,,,I drilled the wood just fine down to the steel and left the mark. I then took off the handle and tried to drill out the steel.
NO GOOD,,,,It would not drill at all,,,The steel was rock hard,,,It burned all my drill bits up,,,
Now,as I had already drilled the oak handle 1/2 the way, it had to be tossed out when I gave up.
But,,,,,what if I had used my new torch, and heated the steel up where I wanted the pin to go untill it was red,,,red,red RED hot, then ran to the drill press and tried to drill it?
what would have happend?
