- Dec 2, 1999
I was lucky enough to aquire 2 industrial bandsaw wheels that were slightly over 1" wide. I had a machine shop turn them both down to 1" wide and sent them both to SunRay for new rubber (poly urethane) actually at 90 durometer hardness. I'm keeping one and selling the second one so I can have mine for free. Good thinking eh?
Anyway I'm tossing in 1" shaft made of 4140 to sweeten the deal.
This wheel is made in the USA and of very high quality. It has two set screws instead of a keyway. A machine shop could cut a keyway for you but the large fine thread set screws may be plenty adequate to hold the wheel onto the shaft.
I need $350 plus $25 UPS shipping to break even. Not a bad price considering what you can do with this wheel. The narrower 1" width is excellent for inside radius grinding such as on tactical blades. I'm using mine for pocket knives as my 2" is not suited as well as this will be. I,m designing and building an entire new grinder for mine. It will be only 3/4 hp variable speed and geared with pulleys so the surface feet per minute is very low for adequate control and low temperature grinds.
Here are some pictures
