- Sep 28, 2005
The "gross" one I've been told when I've mentioned it: Never underestimate the strength of human hair, especially if you are a dirty hippy or travel with a beautiful woman. A small amount of hair on a brush can make emergency string, and can make very strong rope. If in a true survival state it can be cut off of the head and is already in parallel lengths which make it easier for layering in when lengthening. It also rolls along pants/in hands very well if that is your chosen technique- but some moisture in the palms is wanted.
The fun answer:
Find a 1" or so willow branch/tree. Cut off a 6" or so chunk. Score around the circumference about 2" away from one nicely trimmed end. Cut perpendicular to the length about 1 1/2 away from the nicely trimmed end (keep the end smooth). Cut at a 45˚ angle into the bottom of the perpendicular cut from the near side. Gently beat the stick with another from the nicely trimmed end to the cut along the circumference to free the fibers. Gently twist the stick to free the bark and outer fibers at the depth of the score. Pull apart and make a small chamber behind the 45˚ cut on the long piece. cut toward the tip on the top parallel to the length to create the opening to the mouthpiece. Gently push the pieces back together and blow.
Pictures are really worth a thousand words (it took me longer to write it than it did the first time I ever did it):
The fun answer:
