Rookie82
- Nov 25, 2014
I'm curious to see who scored the most points. Post your scores and lets see who did the best! Perfect score would be 11 points.
1. Buck vs GEC. (+1 point if you wanted a Buck.)
2. Buck model voting. (+1 point if you voted for a 301.)
3. Blade voting. (+1 point if you chose 2 blade opposite ends, over jack style or 3 blade.)
4. Steel choice. (+1 point if you voted for CPM154 over the other options.)
5. Bolster choice. (+1 point if you voted for nickel silver over brass bolsters.)
6. Blade grind choice. (+1 point if you voted for for full flat grind on both blades, instead of hollow grind on both, or combination of the 2.)
7. Pull choice. (+1 point if you voted for double long pulls, instead of double nail knicks, or a combination.)
8. Handle material choice. (+1 point if you voted for American Elk, over the 100 other options.)
9. Elk style choice. (+1 point if you voted for knobby elk over smooth elk.)
10. Pins choice. (+1 point if you voted for pins over no pins.)
11. Bolster groove choice. (+1 point if you chose no-grooves instead of grooves.)
Lets see the scores!
I scored a 7/11.
I scored a 7/11.
