Lol. If I do you might get stuck with it.You need to do hidden tang for sure.
I like 3. I just prefer western handles. I need to make a pile of wa handles but I haven't gotten around to it. I do like that they use less steel. Those 11.5" pieces from AKS are pretty had to get a full size knife out of if you do western handles.
Should that be 1, 2, and "4"? Are 2 and 4 similar except for length?So, it looks like profiles 1,2, and 8 are the choices. Is three ok JT?
Did some pin hole tests today and I’m considering switching to just popping a start hole and drilling after. What’s you thoughts?
1/2” to .062” the .062 is just a pop to drill later.
I sorta like that idea - I think most any of us can use the .062" hole as a guide to drill after HT just fine, and it's small enough if it's decided later to make a full tang to hidden tang the holes are small enough not to be a problem. BUT - as Willie says, "JT, you know best". {g}.062 is just a pop to drill later
The issue I have was I can’t guarantee a perfect hole size so if it cuts small it would have to be drilled anyways which would be harder if only removing a small amount of material. My thought is I can drill the holes here befor heat treat for people that can’t or don’t want to do it them selves.
Hey Willie, if you want, you can send them to me and I’ll trace ‘em in Inkscape and send them to JT in whatever format he wants...
Try to spread the workload out a bit...
If you want you can send them
Stright to me. Will only take me an hr or so to trace around them and get them scaled correctly.
Also playied around with the start hole and did a batch like this. It’s really just a centerpunch mark. Only about half way through. After I knocked all the dross off I drilled them with a 1/8” carbide burr and stepped to a HHS drill bit for final size, Worked perfect. I tryied a carbide center drill but thoes things are historically picky about everything. The little carbide burr went through it like butter.
