Hello everyone. I've never posted in this section, but since I recently got some CPM 20CV from Niagara Specialty Metals (NSM), I have a couple questions that I need help with. NSM included a chemical analysis of the chunk I got. It has the following composition in percentages:
C 1.920
Si 0.670
Co 0.040
S 0.013
Mn 0.330
Cr 20.850
W 0.630
P 0.016
V 4.040
Ni 0.150
Fe balance
I'm specifically wondering about how this variation from the standard spec might behave during heat treat and subsequent use. I have yet to heat treat any stainless steel, so I'm actually starting at the point of looking at datasheets. The Co @ 0.040, Cr @20.850, and Ni @ 0.150 are what intrigue me most.
For those who understand stainless steel metallurgy as affected by small variables like these, how would you expect this steel to differ in a standard heat treat from the published specs?
I am leaning towards the following:
2100° austenitizing,
-100° cryo,
600° tempering.
Without more experience, I think this is the best course of action to start.
With regard to expected hardness, should I expect this specific alloy to come out slightly harder or softer than the published data indicates?
Beyond hardness, toughness, and wear resistance, I am curious about corrosion resistance. I know it will be excellent regardless, but with that extra 0.850 of Cr and 0.150 of Ni, is it reasonable to expect improved corrosion resistance? I understand that it will be an immeasurable difference in use, but I'm still curious for understanding's sake.
Thank you in advance to any and all who can help clarify the situation or make helpful recommendations.
Attila
C 1.920
Si 0.670
Co 0.040
S 0.013
Mn 0.330
Cr 20.850
W 0.630
P 0.016
V 4.040
Ni 0.150
Fe balance
-100° cryo,
600° tempering.
Attila
