I think you have a bad idea about oil, well dimensioning quenching plates makes it work far faster.
I don't understand what you mean. Would you be so kind as to elaborate?
With these monsters of about 17 kg Al ... time to room temp is 1min, now you try oil and get the resultI don't understand what you mean. Would you be so kind as to elaborate?
That sounds good, I am a little surprised that the rc didn't change after LN..Must have been very little RA left???After second temper it stayed at 61-62 which is what I was shooting for. This was just a coupon so I didn't grind it. From here I'll do some knives but I'm going to grind a fair amount pre HT especially with 20CV. It's hard enough to finish with only a small amount of grinding to do after HT I don't want to complicate things![]()
Whether or not plate quenching is faster than oil doesn’t matter that much for air hardening steels. It is significantly faster than air.
The oil quench is suitable for any steel out of the air hardening classes. The thin cross sections get higher hardness after quench (greater volume fraction of martensite) and a less stabilized volume fraction retained austenite. (The volume fraction of RA can be expected (near guess) between 20 and 30% or even higher)
Do his words contradict what I said?Roman Landes words ............
Not at allDo his words contradict what I said?
Of course this is a bit non-standard, but I claim that any piece of Al that is thicker than 20mm(+ air from the compressor) will be quite sufficient for a faster time than the oil.
