by the charts that fitzo linked to it showed that temperature makes a pretty noticible differance. also since when you decompress the tank it cools, it has less temperature change to go through until it freezes.
you can always try when the psi dramaticaly drops, to (with the valve in the off posistion) to gently shake/rock the tank to see if there is a chunk of frozen propane in it (becareful with this, i do not see much danger as long as it is closed and no flames around but im not taking any liability.)
im taking this info from my experances with co2 again, espicaly when there is a substantial decompression the gass will freeze and form a huge chunk (enough in co2 tanks that you can replace burst disk that blows out when the psi spikes and still have a full tank when the chunk melts )
-matt
-matt
