220V or 110V bader grinder
If you want 2hp you need 220v. If you buy the 1.5hp then you need 110v. If you have 220 in your shop, definately get a 2hp motor
The 220 draws 1/2 the amperage at start up over the 110 hookup. The motor will run slightly cooler with 220. The 220 will be more expensive to install.
You can not. It is hard to even get 1.5 hp in 220 vac do to the lack of vfds but the KBAC-27 is great for it wide running range. Singal phase three phase 110vac 220vac and up to 2hp. all from one controller. You will not find another vfd that will do that in one package.
Killabea shoot me a email I have some info for you. brettandmira@gmail.com
Brett
Get 220...
I didn't know you could get 2 hp variable in 110?
