$25 Furnace for Forging
My son and I had to produce an "instant furnace" last week, and put together this home-designed , home-made small, portable furnace.
This isn't the sort of thing you can make a living with, and there are a lot of better designs that are more efficient and cost effective to run, but if you need a fast source of high heat, this one does the trick.
What's involved is two steel wheels, a small blower, a piece of pipe, a little welding, and about an hour.
Here's the link to the full story with more pictures and more details on construction.
As I said, it's not much to look at, and certainly primitive by most standards, but it sure worked for us.
Where are you in North Mississippi? My parents are in Batesville.
Somewhere in that neck of Sissimippi there's a car in someone's front yard missing 2 tires and they probably won't notice for years. :confused: Did you have to cut many weeds to get to the tires? what 'bout snakes? :p
Really neat forge and I'll make sure I direct new smiths to this thread. You done good for someone from Sissimippi. :D :thumbup:
I welded up my first damascus in a truck rim coal forge. I used a hair dryer for the air flow and flexible dryer hose. It actually worked pretty well. I just hated having to tend the fire, so I switched to propane after about a year.
We use bud rims off big trucks as fire pits at Scout camp, and that got me to thinking about using a wheel for a forge. I figured if I stacked one atop the other, I could make a forced air chamber.
In any case, it took less than an hour to assemble, and we were heating steel the same night. Simple, but it did what we needed.
