Uncle Timbo
- Nov 23, 2005
I ran across a 263 HiLine and wondered if anybody has one and what your thoughts are about it?
I also was curious as to why Buck didn't change the root part number (model) between the HiLine and HiLine XL.I have the original, smaller version and it's well built. The pocket clip is too thin and won't come out of the pocket without a tug 'o war. I'm a little surprised that Buck used the same model number for the XL. If this blade shape was made in the USA and was in a 110 or 112 frame, they would probably sell a ton.
Are you sure about one side being stainless on the smaller knife? The description only says anodized aluminum handle. I commented in the original post that I wondered how the frame lock worked with aluminum and no liner. I noticed the significant weight difference and assumed it to be a typo. The description for the XL describes the scales as G10 one time and Micarta another time in the same listing so some error there also. I have a Copper colored XL coming along with the 110/112 N/S drop points this week. The blade stands tall and is very light in action so it opens with very little resistance. My large hand pinches the blade about mid point so the grooves don't come into play.The XL has 2 aluminum scales and a liner lock, while the smaller Hiline has one side made of stainless steel for the frame lock and the opposite side is aluminum. Buck reports the weight of the original as 3.9 ounces and the XL is only 3.17 oz. It's bigger and lighter - can't argue with that.
Uncle Timbo P plb
Uncle Timbo P plb Are you sure about one side being stainless on the smaller knife? The description only says anodized aluminum handle. I commented in the original post that I wondered how the frame lock worked with aluminum and no liner. I noticed the significant weight difference and assumed it to be a typo. The description for the XL describes the scales as G10 one time and Micarta another time in the same listing so some error there also. I have a Copper colored XL coming along with the 110/112 N/S drop points this week. The blade stands tall and is very light in action so it opens with very little resistance. My large hand pinches the blade about mid point so the grooves don't come into play. About closing it one handed. I have found the the blade is so smooth and friction free in rotation that if you unlock with the blade high it will free fall onto your thumb. (it's sharp!) I'm a quick learner and only did that once....
