Can somebody explain the 277 Folding Alpha Hunter geneology? Some with ATS-34 , some with CPM-154 ? Wood and Kraton handles?Are they still made or still available?
The knife was available with a rubber handle, 420HC blade, and nylon sheath.
It was also available with a resin impregnated rosewood handle, ATS-34 blade, and leather sheath.
Then, a couple of years ago, Buck switched the steel in the rosewood handle version from ATS-34 to 154CM (not CPM154). ATS-34 and 154CM are nearly equivalent products. ATS-34 is made by Hitachi in Japan and 154CM is made by Crucible Metals in the USA.
The rosewood handle/154CM blade version is still available and is a current model.
I believe the rubber handle 420HC version is still available and current as well.
Hope this helps.![]()
Is the 154CM a Bos treated blade. Have the stamp?
I know the ATS 34 is.
