- Jun 11, 2006
well after fighting the lighting all night this is all i could get. i might try again later. but for some reason i just cant get an even reflection and lighting on the blade. also the camera was having a hard time getting a good focus. maybe its time for a new camera. the blade is M2 at around .090 thick hardened to 64.5. or should i say that's how it came. i made it from a power hack saw blade. it was so hard to grind it that i had to get it close with a 60 grit belt and then hand sand it the rest of the way. that is also why there is not a clean sharp edge bevel line as it smoothed over with the hand sanding. It took me probably around 5-7 hrs of just hand sanding with 240 grit norton paper to get all the worn 60 grit scratches out. i then went over it with a 600 grit then gave it a run on the scotch brite wheel to give it a satten Finnish, the handle material is Carbon fiber with lovles bolts. there are 6 milled out slots for grip. it turned out very nice. to bad the picture is not as good as my last one. but bubba-doll is as good as ever. This has to be the hardest knife i have ever taken a picture of. o well you get the idea.
This is the knife i am thinking about doing a small production run of maybe 50 or so. It is a a refined version of my standard 2nd Amendment.
