This is my 2nd knife, 3/16" 1084. I heat treated it using my home built propane forge byfollowing Staceys instructions,.. heating to 1500 then cooling in canola, then to 1300ish cooling in oil, then to 1200 cooling in oil again. Then heat to 1500, quench, temper twice for 2 hours each time. I then just ground off scale and down to an edge and sharpened, didnt worry about trying to finish the blade at this time. I wanted to test it to see how good or bad it was. The picture shows results. I started with it shaving arm hair sharp, whacked the 2x4 300 or so times. At this point in the middle of the blade where most of the hits were, it didn't shave arm hair, but still could at tip and lower part. I then whittled the 2" plus hardwood branch to a point, stabbed the knife tip into the branch very solid 300 times, then whittled on piece of oak flooring. AFter all that, definintely couldn't shave hair anywhere, but it still cut the paper fine as you can see.
I know this is probably a cave man way of testing, but I'm not sure of a really good formal process for me as a newbie knife maker. I don't have a really nice custom knife to compare to, but i know niether my leatherman, any pocket knives, or my current Ka Bar would hold up as well. So, I guess that's a good sign. I'm interested in how other's test their knives, and do you test each one before making it all pretty and putting on a handle? im looking for something to compare to in order to gauge how good or bad this blade may be. Oh, I did perform the brass rod test...bending blade over rod at tip, rolling blade all the way to base watching the deflection and checking that everything returned back to normal with no deflection left. I did it to both sides of blade. I have a couple guys that want me to make them a knife, but Im hesitant with just starting out as i don't want to deliver something that would disappoint. Any suggestions are most appreciated.
Thanks,
Ben
Thanks,
Ben
