- Jan 17, 2009
Short story - I just bought a 2x42 grinder (Palmgren and did the mods that every youtube video said to do.)
3/16" 1084. I used the Grinder to do the bevels and got the edge to about a dime in thickness. Heat treated it in a 2 brick forge. It's currently tempering now. I don't know how to get the edge down and they sharpen it. I ruined my first knife trying to grind it down after tempering.
Long story - I made my first knife (stock removal method) with an angle grinder. It wasn't pretty. However, it started to clean up nice when I got the belt sander and I took it to some 40 grit ceramic belt. I took it to 80 and 120 grit using ceramic belts. Then I got the bright idea to to use the marketed X weight 220 grit for profiling and sharpening. I bought 220, 320, and 400 grit x weight alumina oxide belts that say they're for profiling and sharpening. First two passes on the 220 and I turned the edge blue and ruined the temper. They were pretty quick passes but it heated up so fast.
How do I use the high grit belts to get something close to an edge on it or what else can I use besides the grinder? I know the 2x42 is going really fast and heats up fast.
I ordered some Trizact belts in 220 grit and higher. Will they help me finish the blade without heating up so fast like the oxide belts? I don't want to ruin this one as it's not terrible. Again, the edge is about the width of a dime right now.
Also, I'm still terrible at grinding and have been practicing on mild steel. I even made Walter Sorrells grinding jig and still can't get even lines. I've watched the videos and read all the forum tips to get better. I'll keep practicing. And keep practicing free handed.
I'll post pictures of the second knife.
