I realized normal red paper doesn't do much on hardened steel in finer grits.
Rhynowet Redline or something else?
I was referring to regular (non wet sanding) sandpaper (usually red in color). I use Klingospor now and am very happy.Rhynowet Redline or something else?
Put a little soap in your water bucket. It will help sheet the blade better. When I can run my belts a half speed I can spray the belts with a spray bottle with soapy water and it will stay on the belt much longer than you would think. Give it a try. You might be able to get a couple of passes in. I don't think that Trizac works with water unfortunately.
Also for the last couple of passes put on a brand new belt. I save new belts for the last passes and after they lose that first bit of sharpness I will use them for grinding bevels while you have just a little bit more material.
I put a lot of pressure with the ceramic belts up to 120 and was able to make several passes before dipping it in water. I barely touched it with the 220 oxide and it was blue. I don't know. I'll experiment with some scrap and other belts i ordered when they get here.I was referring to regular (non wet sanding) sandpaper (usually red in color). I use Klingospor now and am very happy.
I find it awkward that just one pass on the blade would cause overheating the blade no matter the grit. Maybe if you put a lot of pressure directly on the edge?
Dayton, craftsman, norse, palmgren - they're all the same. How do you finish your knives without ruining them? What belts, etc?Hello all. I'm new here and a new to bladesmithing. I have the same grinder, only it's one marketed by Dayton. Same 2x42. I've ruined a lot of knives on that thing! Sometimes I think if I could go back and start over again, I'd just get a proper entry level 2x72. Buy once cry once, right? I'd probably still have ruined blades, but maybe not quite so many and in the same way. I'm shopping for a grinder upgrade now and saving my money. Still using the 2x42, but being incredibly careful about it! It's taking a lot of time but also maybe teaching me some patience and finesse.
Geronimo my friend , say on 40 grit ceramic belt we have 100 grain on square inch .When you push steel on that spining belt they start to CUT steel .To do that you aply pressure .Now on 220 grit belt you have 2000 grain on square inch and when you push steel on that they don t CUT they are rubbing on steel and create LOT of heat FAST because you can not apply with hand enough pressure .....4480 sfpm is to fast for anything over 80 grit .II put a lot of pressure with the ceramic belts up to 120 and was able to make several passes before dipping it in water. I barely touched it with the 220 oxide and it was blue. I don't know. I'll experiment with some scrap and other belts i ordered when they get here.
Also, I need to read more about sharpening. I ended up putting a secondary bevel for the edge. its sharp enough to cut me but not shave. I'm still excited as it's way better than the first and I didn't think it would turn out this good anyway (I know it's not great but I'm taking baby steps here).
