- May 25, 2015
This blade is simple, no nonsense. A straightforward utilitarian knife meant to work. The tang is a burnt and epoxied dowel fit, and if I'm not mistaken the cherry handle should redden a little over time. A little bulkier at the handle than most of my others.
Asking$180 U.S, shipped. SOLD
- Blade: 246mmx57mm AEB-L (63hrc) 600 grit hand finish
- Neck: 20mmx20mm
- Handle: 130mm, tapering from 26.8mmx22.6 to 24.6mmx20.6mm, cherry, oiled and waxed.
- POB: 60mm from handle
- Spine: 2.51mm at the neck, 1.78mm at 13cm, 1.2mm 1cm from the tip
- Grind: flat to convex
- Weight: 172 grams
- Relieved choil and spine
- Edge: .1mm to near zero at halfway continuing to the tip.
Asking
