- Jan 28, 2008
Well, here she is in all her green glory lol. I wanted to share what I have done for all the guys here thinking of partaking in building their own grinder(and to show off of-course
). I used Tracy's NWG plans to get the basic machine built, I used 1.5" x 1/8" thick steel tube for most of the structure and tool bar holders, I had to buy two pieces of steel I didnt have at the farm, they were 1-1/4" tube steel for the tool arm and for the work rest arm which I haven't finished yet, it fits perfectly inside the tool bar holders, and the 5/8" round bar for the drive shaft. This build took about 22 hours of work to complete from all the tinkering I did with various set ups, I conjured up a few wild ideas and some of em actually worked!
One thing I did was design myself a multi use platen. I looked at several designs before I started, I had some 3/8" thick solid flat iron pieces so I decided to have at it(I used nothing but a 4.5" angle grinder and cut off wheels to cut the shape out, then used a grinding wheel to round the corners), I have a flat platen in between a 2" and 8" contact wheel, I bolted everything together then welded the bolts DEEP to the plate(hence the mess on the back side of the platen attachment, this was a last minute realization) I am going to grind the bolt heads down flush with the steel(I may even paint it again, lol)I can then get full rotation clearance to access all 4 positions of the platen without having to remove it... the platen serves the purpose of the 2" contact wheel, flat platen, 8" contact wheel, and slack belt. Something I did notice though, I think this has been mentioned before, when you have a tool bar that is the exact size of your tool bar holders opening, the weld inside that piece of tubing is going to get in the way, I just took a 12" bastard file and filed it down til it was flush with the rest of the inside, it now works perfectly.
I used 2 drive shafts, the reason for this is the motor I acquired from craigs list has a 1-1/8" bore and I couldn't find a 4 step pulley for it so I used the 6" pulley that was on it, being unrestricted on the bore diameter really opens up your possibilities for a motor. The secondary shaft is driven by the motor, it has 4" pulley and a 4 step pulley that in turn drives the grinders shaft with the other 4 step pulley and drive wheel on it. I placed the pillow blocks on a few pieces of 2x4s and hinged that to the work table(using a commercial heavy duty door hinge) for my secondary shaft, I then through bolted a 3/8" bolt to the table to hold the secondary drive shaft block down using the attached piece of angle iron, this makes for a quick speed change.
The motor is a New single phase 110/220v 3hp 1740 rpm Dayton take off from craigs list. I got the green linked drive belt from harbor freight when I bought my drill press and band saw(knew I would need it for this), the misc bolts and stuff came from the local hardware store, the 4 pillow block bearings are from bearingson, and all of the wheels(the wheels are the poly wheels), pulleys, and grinding belts are from Tracy at USAKnifemaker. Something can be said about Tracy and his business, I have never ran across anyone that had such great customer service, ever, the NWG plans are seriously idiot proof(heck, I did it), he has done a great thing offering these plans for us broke folk and any support he can give throughout the process.
A few things I think are worth mentioning, first the bolts you use for all of your adjustments, if you aren't going to put knobs on em(I prob will later) then make sure they are all the same size so you can use 1 wrench or socket for all the adjustments, also the drive wheel here seemed to be slipping when I applied pressure to the platen at first, 3 things can be the problem here, the first thing I noticed is after running the grinder for about 10 minutes the drive belts stretched and were slipping, I had to remove 2 links from each of them to tighten them back up to where they would not slip. Then I noticed the sanding belt itself was stopping while the drive wheel continued to spin, this was due to the tension arm not having enough tension and the drive wheel needing some more "grab", so I shortened the spring considerably to put a good bit of tension on it then I put some electrical tape around the very center of the drive wheel to give it some more grab, I can now push as hard as I can against the platen and the belt may slow down a little(this is on the slowest speed) but it is still throwing a LOT of sparks and running like a champ, and I def cant bog down that motor.... its a beast. Oh yeah and its been said a thousand times... watch where you put your hands, and make sure you dont have any baggy clothing near the machine, with all the spinning parts, you could lose a limb very fast, I wasn't paying attention and just barely touched the drive belt with my finger whiel looking at something and now Im missing about 3 layers of skin there lol...
Here is a break down of what I spent.
Motor - $120
Wheels, Pulleys, Drive Belts, Pillow Blocks - $370
Misc Bolts and Nuts - $15
Steel - $20(I had most of it)
For a total of $525
Now, I had all of the electrical components and most of the steel so that would prob add to the cost, but not by much if you get the steel from a scrap yard.
If anyone has some advice on dampening the vibration from the motor Id be much obliged, its not a major problem, but less noise is always better and as you can see I have a steel framed shop...so the vibration transfers a lot more.. I also am trying to figure out the tool rest deal, I like Tracy's design in the NWG plans but would like something that pivots on the x axis to give me the option of setting it at a certain angle... any ideas again...hit me.
And as we all know, pics or it didn't happen
Motor - $120
For a total of $525
