I have been avoiding asking this question for over a year. When I hand sand I lubricant the paper with wd 40. That works out great for me. When I grind I use a dry belt. Is there a prep protocol for belts?
Wd40 may work amazing on a belt, but that would get messy quick.
I have used it on my disc grinder though and seems to do well.
You have some proof that the directionality really means something in a belt??? ———————————————-To me it looked like a way for the belt company to get out of being sued! ——————-The belt breaks and something bad happens. They can just say, well you must of put the belt on the wrong way!Thanks for the feedback. The one way directionality of the belt makes sense. I will forgo belt prep.
On the comments on lubricating abrasives, I tried simply green and windex but found that I could feel the cutting better with wd40. IMHO.
I've always thought the direction was indicated due to the way the splice is, but who knows.You have some proof that the directionality really means something in a belt??? ———————————————-To me it looked like a way for the belt company to get out of being sued! ——————-The belt breaks and something bad happens. They can just say, well you must of put the belt on the wrong way!
Kevin, I’ve heard that too! But the slice will ether lead on one side of the Platen or the other. How could that make a Diff??I've always thought the direction was indicated due to the way the splice is, but who knows.
I've thought the same. If the splice was an overlapping splice it would make a difference, but I believe they are all butt spliced.Kevin, I’ve heard that too! But the slice will ether lead on one side of the Platen or the other. How could that make a Diff??
That makes sense! Let see?———/////-We have the diagonal Splice, which runs on the left or Right. ————————////Then the ones that look like intertwined knuckles and I won’t buy those because of the big bump! Any others you might use?I've thought the same. If the splice was an overlapping splice it would make a difference, but I believe they are all butt spliced.
He is.....I mean I was.I think he’s referring to the comment I made about the belt spinning in one direction and not about the arrow on some belts.
By the way, I use the arrows on the belt as an indicator of how I used it last. I figured that it was a good idea to always have it spin in the same direction. Kind of like a car tire.He is.....I mean I was.
I run then one direction and then when they seem like about 30% of the grit is gone, I then run them the other way!——-My theory is that the grit has been fractured one way, so I want to fracture it the other way for another 30% or so ... ————————-//-//////————////No idea if it works any better? But after about 60-70% of the grit is gone, the belt goes to the non HTed work pile because they start to build up to much heat for my liking while sharpening & grinding my HTed Blades....By the way, I use the arrows on the belt as an indicator of how I used it last. I figured that it was a good idea to always have it spin in the same direction. Kind of like a car tire.
