djolney said:I guess that means that the stock was at least one quarter, and then they made a knife out of it.
I still don't understand the obsession with fat blades: the better the steel and tempering process, the less steel you need to do the same job well.
djolney said:Clearly, I'm never going to understand this seeing as performance is my principle concern.
djolney said:I like the fact that Jerry makes both so that we are all happy.
Edge geometry is more important. If you look at where the grind stops on the regular (shorter grind) and where the grind stops on the thicker blade (longer grind) You might come to the conclusion that the blade geometry is the same, which, from what I understand BOTH will have the same cutting angle.djolney said:I still don't understand the obsession with fat blades: the better the steel and tempering process, the less steel you need to do the same job well.
Jerry Busse said:The knife needs to be measured near the handles. The blades are tapered at the point where it appears the measurement was taken.
Hope this helps,
Jerry
MikeH said:Personally, I would love to have a true 3/16" Fusion Steel Heart. A ZT SH on steroids!
GALAXYTECH said:strange![]()
but the thickness in between the scales on mine are 1/4 ,,,but from the end of the scales out are at 3/16![]()
oh,well
Hope this helps,
Jerry
randucci said:MMMMMMMMMMMM 5/16" HOFSH, 'ought to be right at .310-.300
Dark Nemesis said:Thats not a problem...some people have a "thing" for thick knives and some people don't![]()
