- Oct 5, 2005
This one is closer to 1" thick: https://www.youtube.com/watch?time_continue=1842&v=CJrGA3J0nB8
That's some honestly nice work, there.
3/8" is 9.5 mm, so this one is just a smidgen shy of that at 9.0 mm even (0.354"): Still worthy of inclusion... Jean Tanazaq Rambo 21, 40-50 made, 35.2 ounces with sheath:
Gaston
If you want 3/8 or thicker, Himalayan Imports Khukuris is the way to go. No one does knives thicker. The 15 Ang Khola is almost over 3/8" thick. The 18 inch Ang Khola is about 1/2 inch thick and the 22 inch Ang Khola is about 5/8" thick.
Is that full tang? Custom ordered?
No, that is just a standard khukuri from himalayan imports. It is a hidden tang.
It's definatly full tang, i did some more research. It was custom ordered in full tang i believe. Never knew HI did that. http://www.bladeforums.com/forums/showthread.php/672946-This-Place-is-Awful
The question is why do you want 3/8"? I think it turns a normal knife into a wedge, chisel or prybar or something like that. If you need the extra weight or strength then that is OK. For cutting it will get in the way but if you are striking with the tool then that is OK.
I've seen a few competition chopping blades and I think they were perhaps this thick at the spine but the blades are tall enough that the bevel angles are not too steep. In that situation I think they used the thickness to gain mass for chopping.
Here is one:
I alredy posted in over build knives ,.375 thick A2 tool steel , I also made knives in .25.
if you do deep hollow grind you actually can make them sharp.
