Mark Williams
Moderator
- Nov 28, 2000
Do the 3600 rpm motors generally have less torque than the 1450
rfrink said:Wayne is exactly right. HP=T X RPM . When comparing 2 motors with the same HP...but different speeds, the faster motor has proportionally less torque. (ie: 2x speed----1/2 torque). Pulley ratios can "gear down" a fast speed to make more torque...if you gear down to 1/2 fast...you'll get 2X torque. Viola! a 3450rpm motor geared down 1/2 fast will have the same torque as a 1725rpm motor....both with the same HP. This also works the other way... over drive a 3450 to say 6900rpm...and you'll drop the torque by 1/2.
Dan Gray said:![]()
rob if the 3450 motor is rated at 1 hp,, at that speed won't it double the hp
geared down by 1/2 to 1750?
1750 rpm rated at 1 Hp, using a 2" sheaved pulley =? hp
3450 rpm rated at 1 hp, using a 1" sheaved pulley =? hp
would not the 3450 motor have
double the HP of the 1750 motor at the belt...?
not talking torque here ,, I'm talking HP...
you're going to tell me that torque is worth more than HP right![]()
Fatzo!!! Now you are sounding as thick headed as Dan.fitzo said:So lemme see if I understand this:
if I pack the coal directly around the motor and light it the heat will produce "contact watts" and thus more HP without all the resistance loss from those transmission lines, right?![]()
rfrink said:Dan, HP and torque are completely different entities. HP is a measure of energy...torque is a measure of force.
Energy is the product of Force and Speed. Or HP=TorqueXRPM
It boils down to the "basic energy in = energy out concept"
HP is the energy put out by the motor...it is directly related to the energy taken in by the motor measured in WATTS of electricity. So for a given system...if you put 1HP into the system...at best you'll only get 1 hp out. You cannot get more out than what you put in.
If a 3450 motor is rated at 1hp....then it is always 1 hp. ... gear it up or down or sideways...it is still 1 hp. It still takes in 1hp worth of electricity and still puts out 1 hp worth of energy.
Imagine, if you took the 1hp motor and geared it down...1/2 speed...no say 1/20,000...this won't make it a 20,000 hp motor... it is still 1 hp. But due to the gearing, you will increase the torque 20,000X and it will turn very very slow...and will take forever to move anything.
HP is Energy. In engineering, energy is never gained or loss...it simply changes and can always be accounted for. For example, a piece of coal has a given amount of chemical energy(calories)...the coal is burned...producing heat (thermal energy BTU's) ..heat is used in the power plant to make electricity(watts)...which runs the motor....which is used to raise a weight...which is dropped to forge a part...etc....
So..if we are talkng HP...we are talking Energy. Which can be BTU's, calories, watts, joules...there are many different units to describe the quantity...and HP is just one of them.
For your given machine...if you need a lot of enegy output....you need a lot of energy input.
Heck I'm not sure if this made any sense...but have fun with it.
-Rob
ysforge said:so, ideally, the motor you should be running would be as close as possible to the final output speed you need.
Mark Williams said:Do the 3600 rpm motors generally have less torque than the 1450![]()
